Author Topic: Copy Markers from spline to spline  (Read 3834 times)
arch3d
    • arch3d.pl
« on: February 25, 2023, 10:31:37 am »
Would be great to copy marker from one spline to another with all data (Marker ID, Spline Data)
Re: Copy Markers from spline to spline
« Reply #1 on: February 27, 2023, 09:30:13 am »
Well, it could be done, but markers depend of the underlaying spline (number of sub-splines, vertices, etc.).
Copying them to a spline with different structure would result generate a weird result.
arch3d
    • arch3d.pl
« Reply #2 on: February 27, 2023, 09:43:48 am »
So main issue is that copied marker would be in wrong place?
« Reply #3 on: February 27, 2023, 10:18:23 am »
Yes, besides other issues, as what to do with markers from a spline with more sub-splines than target. For example, marker in sub-spline 2, copied to a spline with a single sub-spline.
Anyway... you suggestion was to copy markers within a same RCSpline modifier (copying between sub-splines), or copy between different modifiers ?
arch3d
    • arch3d.pl
« Reply #4 on: February 27, 2023, 10:25:38 am »
From one modifier to another.
For now my pipeline is copy whole modifier and remove unnecessary markers (to not set it up again)
« Reply #5 on: February 27, 2023, 11:53:37 am »
Ok, added to the wishlist. We'll search some workaround to avoid those side effects.
arch3d
    • arch3d.pl
« Reply #6 on: February 27, 2023, 12:17:47 pm »
thank you
