Author Topic: Corner Alignment when using 1S generator in 3 dimensions  (Read 2629 times)
SeanRedmond
« on: October 03, 2022, 07:08:45 pm »
I'm having issues getting corners to align when using a 1s generator in 3 dimensions. attached is a working example I have using material IDs to rotate the corner alignment, but I really dont want to use mat IDs for this because i'd like to use them for something else and dont want to overcomplicate the style. Is there a cleaner solution? Thanks!
Re: Corner Alignment when using 1S generator in 3 dimensions
« Reply #1 on: October 04, 2022, 09:58:09 am »
Using Markers (you can address the desired ID by the X Spline Marker ID option within the Selector Operator) could be a good option for these cases.
