Author Topic: Railway sleepers with new sleeper at each corner  (Read 2434 times)
chrisc0le
« on: November 29, 2022, 05:47:52 pm »
HI All
I'm not sure I've described this is the best possible manner, but It's all I can think of right now (so apologies)
The aim is to follow the outer edge of a shape with railway sleepers. With a new sleeper starting at each corner instead of a bevel (see attached ref image)
I am unable to have railclone make the sleepers end at each corner and a new sleeper to start with the offset of 10cm (sleeper thickness). Any solution i've come close with isnt 100% right and corners facing opposite directions are just facing the opposite way.
Here is an example (see closest corner)
Thanks in advance.
Re: Railway sleepers with new sleeper at each corner
« Reply #1 on: November 29, 2022, 06:04:57 pm »
Please see the attached sample. To recreate it you'd need to do the following:
- For the Segment, disable Bend and Slice
- Wire a Null segment to the Corner input.
- For Generator > Rules > Default settings, enable Adaptive mode and turn off Scale Padding
- For Generator > Rules > Corner set Bevel mode to none.
- Now adjust the Padding for the sleeper. Add a positive Right padding to move the sleeper following the corner, and then a negative left padding value to close up the gaps.
I hope that helps,
chrisc0le
« Reply #2 on: November 30, 2022, 09:02:44 am »
Ah so simple when you explain it, thanks Paul!
