Author Topic: RC4 Problem. Please HELP!  (Read 2928 times)
Sergey_Dobrij
« on: June 13, 2020, 01:08:40 am »
Greetings! I decided to redo all the railclone parameters and ran into a problem. Corners I can solve with BC Offset. But there is another problem - this is the window. Please tell me what could be the problem? Thanks!
This is the finished scene from the Railclone tutorial
Re: RC4 Problem. Please HELP!
« Reply #1 on: June 13, 2020, 05:49:02 am »
It depends on your style setup. Please check the Adaptive either for Default or X-Evenly.
Sergey_Dobrij
« Reply #2 on: June 13, 2020, 09:03:48 am »
Hello! Thanks for the answer. Everything was fixed. I actually did it, but it confused me that everything had worked before. And in the lesson are the parameters as I showed you in the screenshot. Has there been a change that I did not keep track of? Thanks!
