Author Topic: Parametric Wall ; How to do this?  (Read 4608 times)
BH1231
« on: January 19, 2016, 12:56:53 am »
I'm a new user of railclone ---   is it possible to create a parametric brick wall using railclone 2?  not sure how to get a brick wall (2d array) to follow a 3d surface; versus just a spline (which I can do; and understand how to make it follow a terrain surface in plan; the question is how can you align the brick wall to follow to a surface in elevation???
http://torabiarchitect.com/parametric-array/?p=889
« Last Edit: January 19, 2016, 01:31:54 am by BH1231 »
Re: Parametric Wall ; How to do this?
« Reply #1 on: January 19, 2016, 10:12:58 am »
Thanks for contacting us. When using surfaces, RailClone always projects its geometry on the local Z axis, so to use it to create a wall you would need to rotate the RailClone object 90 degrees on the X axis or create it in a front or side  viewport.  I've attached a sample file to illustrate with two RailClone objects, one in the usual position on the XY plane, and another that has been rotated to create a wall. I hope they help.
You might also find this chapter on Surfaces from our Next Steps with RailClone guide useful as it goes over using surfaces in more detail.
Many thanks!
