Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Corner problem
« previous
next »
Print
Pages: [
1
Author
Topic: Corner problem (Read 4596 times)
lebonmarie
Newbie
Corner problem
on:
January 19, 2016, 02:27:23 pm »
I have problem with corner for make that ! How can I do, for build stairs in this form ?
I put cuve steps: 500
Logged
ITOOSOFT
Hero Member
Re: Corner problem
Reply #1 on:
January 19, 2016, 03:55:12 pm »
Thanks for contacting us. Generally speaking you will get the most accurate deformation around a corner like this when the spline is in the middle of the segments. Because the distance to the furthest edge is not so great, small inaccuracies in the spline are not magnified, as illustrated in the image below.
If this doesn't help if you can upload your sample file it'll be helpful to help solve the problem.
Many thanks!
Logged
lebonmarie
Newbie
Re: Corner problem
Reply #2 on:
January 19, 2016, 04:12:29 pm »
I've the same problem when i put splin ein the middle
Thanks for your file, but I prefer understand my problem for next time
Logged
ITOOSOFT
Hero Member
Re: Corner problem
Reply #3 on:
January 19, 2016, 04:22:18 pm »
Would you mind uploading your file so I can take a closer look at it? If you'd rather not upload it here you can send it to support@itoosoft.com.
Many thanks!
Logged
lebonmarie
Newbie
Re: Corner problem
Reply #4 on:
January 19, 2016, 04:31:44 pm »
Logged
ITOOSOFT
Hero Member
Re: Corner problem
Reply #5 on:
January 19, 2016, 05:41:54 pm »
It looks as though the problem may be caused in part by the spline, it doesn't form a perfect circle in plan view.
Tight corners where the edge nearly converge on a point are very sensitive to small deviations like this. I've attached a file with the spline corrected.
I hope that helps, many thanks!
Logged
lebonmarie
Newbie
Re: Corner problem
Reply #6 on:
January 19, 2016, 05:55:45 pm »
OK, is it necessary absolutely that the round is perfect?
Thanks a lot
Logged
ITOOSOFT
Hero Member
Re: Corner problem
Reply #7 on:
January 19, 2016, 06:04:01 pm »
No problem at all, glad I could help out. In this case it would appear the circle has to be very precise, a small deviation in the centre of the step becomes quite large on the outside edge.
Many thanks!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Corner problem
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
