Author Topic: Help on creating random sized cobblestone road, following a spline path.  (Read 10766 times)
KQ4371
Hi there.
I'm stranded, with a problem i cant wrap my head around in Railclone.
i want to create a road of different sized stones (see Attached Excample01.png).
The stones have to follow a spline ( green spline on Example04.png)
my Railclone setup is as seen on Attached Example02.png.
My problem is that i get the result you can see on Attached Example03.png - i can´t se to get it right.
can someone help me?
Best regards
Michael
« Last Edit: July 10, 2024, 12:50:38 pm by KQ4371 »
Please take a look to the attached sample.
I used a parameter to define the size of array on Y, and same value divided by 2 to apply a negative Y offset.
KQ4371
hi there.
Thanks for the reply!!, its close, but I'm trying to get the random cobblestones to line up 90 degrees to the X-spline.
Best Regards
Michael
Hello Michael,
Thanks for clarifying. Please see the attached file which uses an L1S generator nested inside another L1S generator to create that effect.
Please let me know if you have any questions,
KQ4371
Thank you so much!! for the reply, that was the solution to my problem!.
Thanks!
Best regards!
