Author Topic: shelf stacker macro  (Read 2445 times)
Pierre
    • Studiosezz
shelf stacker macro
« on: July 07, 2023, 08:40:05 am »
I would like to populate supermarket shelves with the shelf stacker macro.
there is a tutorial that explains how to use the old macro but not this one. Is there a help page for this macro?
I connected a spline to the Xspline parameter and a sequence operator to the scatter items parameter but  I can't use it properly.
How to adjust the spacing between the shelves for example?
Thank you for your help
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: shelf stacker macro
« Reply #1 on: July 07, 2023, 01:04:18 pm »
Hi Pierre.
Thanks for bringing this to our attention. We had to remove those macros because they were not behaving as expected, the replacements lack some of the features of the original. We'll look at creating some official new versions, but in the meantime the attached file might be able to help you. It's an adapted version of the current macro. You should just be able to add your products to the existing randomise node and then adjust the shelf height and other settings as required.
Please let me know if you have any further questions about how it works, or if you spot any issues.
Many thanks,
Pierre
    • Studiosezz
« Reply #2 on: July 07, 2023, 03:33:43 pm »
Hi Paul,
Thank you for your answer, It helps me a lot !
Regards
Pierre
Studiosezz PARIS
www.studiosezz.com
