Author Topic: Corner won't close properly  (Read 2538 times)
IT1371
« on: January 21, 2022, 09:23:52 am »
Sample scene attached.
I have a simple box segment that distributed using the scale mode on a spline.
There are two L1S generators - one limits to material ID 1, and the other one is to material ID 2.
Both splines are identical. All cornered and closed.
And yet, it looks like this:
Just can't get around my head on the "why." Just the material ID changes and absolutly nothing else.
I can work around it with a simple condition, but for the specific case i'm working atm limiting by ID would be preferable.
Re: Corner won't close properly
« Reply #1 on: January 21, 2022, 10:12:03 am »
Are you able to try this with the latest RailClone version? I've tested your scene file here and it appears to be working correctly.
IT1371
« Reply #2 on: January 23, 2022, 11:50:36 am »
Turns out I was still on 5.0.6.  :o
Updated to 5.1.1 and it's generating correctly.
All great now! Should have started with that instead of panicking here  :-X
