Author Topic: Railclone can only inherit UVW channel 1 from geo?  (Read 2481 times)
Rio
« on: April 18, 2023, 04:24:27 pm »
I'm getting some weird behavior, I was under the impression that if UVs weren't generated in the array then RC would pick them up from the segments, but at the moment that only seems to be working for channel 1.
Is this correct?
Rio
Re: Railclone can only inherit UVW channel 1 from geo?
« Reply #1 on: April 18, 2023, 04:37:25 pm »
simple example, map is on channel 2
« Reply #2 on: April 19, 2023, 01:43:59 pm »
It should work for any Map Channel. Can you please try using the Display > Build button to see if rebuilding all stored data fixes it? If you'll be able to reproduce it on a minimal scene, which you can send us, it would be great. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Rio
« Reply #3 on: April 20, 2023, 01:59:07 pm »
You're right, it does work on a simple scene, there must have been something else going on.
