Author Topic: Gutter corners  (Read 5400 times)
Dean
Gutter corners
« on: January 25, 2018, 01:31:24 pm »
Hello!
I'm trying to build a system for building guttering.
I have the basics done, brackets, end stops, down pipes, etc, but I'm stuck on how to do the corners and angles.
I want to copy the style of the T piece, where the vertical and horizontal meet (a slight lip on the ends). If I create a 90 degree piece, I can get this to fit either the convex or concave coners, but not both.
I've tried creating a straight piece, and using the slice / bend options, but neither seem to be right, perhaps I'm doing something wrong?
I'm guessing I need to use a straight piece, and then use Railclone to slice it to fit, as this would also work for the vertical pipes, where the angle isn't 90 degrees.
Is there a tutorial or something on this?
Dean
Dean
Re: Gutter corners
« Reply #1 on: January 25, 2018, 01:53:50 pm »
OK seems I have other issues too.
For the vertical elements, when these are rotated, they no longer behave as I'd like. For example if I rotate the spline 90 degrees, the segments are still aligned as if they weren't rotated, but offset, which again isn't quite right.
Any ideas or tips?
Dean
Re: Gutter corners
« Reply #2 on: January 25, 2018, 06:41:16 pm »
Hi Dean,
We have some gutter styles in the library. A good place to start might to open one up and take a look at how they are built.
Cheers,
