Author Topic: editable poly vs editable mesh  (Read 3437 times)
EU7057
« on: April 12, 2018, 08:00:42 pm »
RailClone Pro 3.0.7 -- Is this a known issue or am I doing something wrong? I can collapse my railclone object to editable mesh and it looks ok, but if I collapse to editable poly the element selection is broken, smoothing groups are broken, etc.
Most of my railclone objects are simple arrays with a spline and element.
EU7057
Re: editable poly vs editable mesh
« Reply #1 on: April 12, 2018, 08:39:33 pm »
it appears the issue is when the segment geometry has capped ends - I was trying to avoid having to make specific end pieces. With the end geometry removed the railclone object seems to collapse correctly and then I can manually cap off the pieces.
