Author Topic: Instances move  (Read 23362 times)
TQ2576
Instances move
« on: November 06, 2013, 05:18:49 pm »
I created a building and grouped it.  I can instance it and move it and everything works perfectly until I save.  Then the railclone objects move off the building out in space.  Anyone seen this or have a solution
Re: Instances move
« Reply #1 on: November 06, 2013, 08:27:44 pm »
As general rule is not a good idea to instance RailClone objects, because the plugin is designed to build the geometry at the absolute position of the referenced splines. Two instanced objects use the same spline, so they may generate strange results if are moved from their original position.
Perhaps we would add a "Free" mode to RailClone, to use the relative position of the spline. This would allow to create instances that can be moved freely. I'll think on it.
p.s.: this problem appears to happen only when scene is saved, because the RC objects are rebuild at this point. You will get the same result clicking the "Build" button.
raistlin
    • My website
Re: Instances move
« Reply #2 on: November 07, 2013, 09:04:25 am »
I've see that problem also.
But maybe, Carlos, could you ask RC to be dependant of the instnce spline?
I've done sometimes RC + Spline to be copied, and everytime i rebuilt, the RC bject move on the first "master" spline, and 'ive to re-assign to the new instances spline... So... could the RC object have a dependance to the new spline? Like a IK rigg copied kept his own hierarchy?
La vie est une aventure dangereuse d'où personne n'est jamais sortie vivant.
Re: Instances move
« Reply #3 on: November 07, 2013, 09:18:12 am »
I will check it. I'm not sure if it can be done, because the "copying" procedure is an internal Max process.
