Author Topic: My DELETE button stops working.  (Read 65455 times)
brlv@brlv.co.il
Re: My DELETE button stops working.
« Reply #15 on: December 04, 2024, 03:41:35 pm »
Windows 11 Pro
24H2
Bobby Parker
« Reply #16 on: December 05, 2024, 03:16:02 am »
I have been reporting this on the AD forum for months. I am currently using the latest plugin and am still having the issue.
« Last Edit: December 05, 2024, 03:21:15 am by Bobby Parker »
RealViz
    • RealViz
« Reply #17 on: December 05, 2024, 06:19:37 am »
There is probably another plugin causing this for you. My guess is that there is a bug in 3dsmax that is triggered by a specific script/code. FP/RC have changed/removed this part and thus the 3dsmax cx error does not occur. However, another plugin can do it.
brlv@brlv.co.il
« Reply #18 on: December 05, 2024, 10:39:44 am »
Windows 11 Pro
24H2
Bobby Parker
« Reply #19 on: December 05, 2024, 09:30:12 pm »
I only have a few plugins, the two primary ones being RC/FP. I could not delete this morning, so the issue is still lingering. It would be odd that it is a known iToo issue and is still an issue for some users after a fix was released.
« Reply #20 on: December 11, 2024, 11:12:38 am »
We found a specific combination of Forest and RailClone lister which may trigger this issue, even with latest updates.
We are actually testing a fix. If everything is correct, it will be included in next FP/RC updates.
Until then, if your Delete key stop working, try opening Forest or RailClone lister, focus it (clicking the window) and then select again in the scene. That should fix it.
DT
« Reply #21 on: January 09, 2025, 05:14:39 pm »
Hi ,
Delete button still doesn't work most of the time. Even after the latest updates .
VRAY 7 GPU
3DS MAX 2024
I didn't update to the latest version yet as my maintenance subscription ended a day before the bug got fixed. Just like the year before when we were plagued by the terrible slowdown bug that locked a thread when using multiple Max instances - in all honesty these are terrible bugs from iToo just as this one is. I thought iToo was a bit better than that, but the latest releases really mess with Max and this should not happen imho.
Anyway I created this macroscript (see attached) to workaround it and I bound it to the following shortcut: SHIFT + DELETE, this way I can keep working and I don't need to restart Max every time I want to delete an object in the viewport. I called it UberDelete.
BK8837
« Reply #22 on: May 22, 2025, 02:38:13 am »
Hi Itoo Team,
This still happens in the latest version 6.4.3. What is the update on this issue?
« Reply #23 on: May 22, 2025, 09:56:29 am »
Hi, theorically this problem was solved in latest updates. We'll check it again.
Do you use latest Forest Pack as well ? What Max version ?
BK8837
« Reply #24 on: May 22, 2025, 06:15:09 pm »
Hi Carlos,
I switched over to the new versions because this was happening. I am currently on:
Forest Pack Pro 9.2.3
RailClone Pro 6.4.3
