Author Topic: How can i get a element in each kerb thta i create on RailClone?  (Read 2912 times)
Final Image
Hello guys,
I am doing some Kerb using the tutorial provide on the support, my problem is after i generate the kerb i want to convert all to editable poly, so i can apply some random id's on each Kerb and so apply a multisubmaterial on the kerb object, to get in each peace of kerb a different material, based on his ID, my problem is that when i convert the kerb to EditPoly each Kerb have different elements, how can i do to get each kerb one single element?
I am sending some images to explain what i want, i need after collapse the RailClone to EditPoly the possibility to apply a multisubmaterial where each material will go on each Element same as the image i am sending that i model, i show you in a printscreen also how my elements looks after i collapse.
Final Image
Re: How can i get a element in each kerb thta i create on RailClone?
« Reply #1 on: July 29, 2017, 12:49:04 pm »
I found the solution!|
I just weld all the vertex than i got the proper element selection.  ;D
« Last Edit: August 02, 2017, 01:04:02 am by Final Image »
TL1895
« Reply #2 on: August 01, 2017, 10:32:01 pm »
I just attach all the vertex than i got the proper element selection.  ;D
"weld vertices?"
Thanks for clarifying
