Author Topic: Tile vs Adaptive rule  (Read 3262 times)
« on: December 03, 2018, 11:42:47 am »
Hi Rokas, please help  :)
I have created a simple generator with some Single/Double Widows and Solid segments.
Since I`m expecting some tweaking I set up some parameters for X segments size and X/Y Gap size...
Now, I have issue with Adaptive default rule since I was expecting that RC will fit "everything" to the Spline length.
3dsMAx 2015, RC 3.2
Thank You.
Best Regards
Re: Tile vs Adaptive rule
« Reply #1 on: December 03, 2018, 11:59:52 am »
Adaptive mode needs all default segments to be the same size for it to work. It applies a single scale factor to them all.
You could use Compose operator for this to work.
« Reply #2 on: December 03, 2018, 12:04:30 pm »
Ok... I switched to the Compose instead Sequence operator I that give me some better results.
Now I have problem with `Full Solid Row` not aligning the Gaps with `Windows` but  this is probably some calculation issue... or it is not?
« Reply #3 on: December 03, 2018, 12:13:09 pm »
 EDIT:
;D
I done Sequence>Compose switch on my own, before Yours answer so I understand why i got difference in alignment.... still do not know how I`m going to fix it  ;)
Can we expect some good news about those kind of situations in RC4?
Thank You
« Last Edit: December 03, 2018, 12:16:17 pm by Dragan »
« Reply #4 on: December 03, 2018, 12:27:13 pm »
DONE!!
Exported X size of Compose Sequence and divided by 5.
With some tweaking with size/gap parameters Alignment will eventually fit.
Thank you
Best Regards
