Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Is this something I should even consider
« previous
next »
Print
Pages: [
1
Author
Topic: Is this something I should even consider (Read 5198 times)
TL1895
Sr. Member
on:
May 27, 2015, 06:31:02 pm »
creating with Railclone?
My initial response is no way, but I've been surprised by the support here many times, so here goes...
Fabric canopies, exactly as pictured...
Thank you,
TL1895
Logged
ITOOSOFT
Hero Member
Re: Is this something I should even consider
Reply #1 on:
May 28, 2015, 09:50:55 am »
Hi!
Thanks for the interesting question. This may be possible with RailClone depending on the shape of the canopy. As long as the geometry could be "projected" along the RC object's Z axis onto a surface that represents the shape of the canopy you may be able to do it. If the angle is too steep or folds back on itself then it wouldn't be possible.
To do this you can use the Surfaces feature, you can find more information about this
here
and please feel free to check out the attached sample file.
If you have any questions please let me know. I hope that helps.
Many thanks,
Logged
TL1895
Sr. Member
Reply #2 on:
May 28, 2015, 01:52:33 pm »
Wow, I am shocked! Thank you so much for such rapid and successful support!
I'll have a look at the example you posted now.
Thanks again,
TL1895
Logged
TL1895
Sr. Member
Reply #3 on:
May 28, 2015, 04:35:50 pm »
Hi Paul,
Actually, I am a bit embarrassed to say I cannot figure out how you made the surface from the spline?
Did you use the "surface" modifier on the spline?
Thanks again,
TL1895
Logged
ITOOSOFT
Hero Member
Reply #4 on:
May 28, 2015, 05:11:53 pm »
Actually I made the spline from the surface in this case by selecting the boundary and using the Create Shape command. The surface was made using a very low poly model (one edge for each peak/trough) with a Opensubdiv modifier (or turbosmooth) to create the curves.
Many thanks,
Logged
TL1895
Sr. Member
Reply #5 on:
May 28, 2015, 05:25:25 pm »
Hi Paul, Okay, interesting, and new to me; Thank you once again
Now I've learned two new things from this post.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
