Author Topic: Crashes when updating Master Style  (Read 3747 times)
Alex.S
« on: February 14, 2019, 12:36:41 pm »
I've been having quite a few crashes when updating Master Styles.
I'm trying to point down the exact actions which lead to the crash. Generally I've been adding extra parameters, adjusting their default values and adding a couple of extra function nodes, such as UVW Xform. Nothing that complicated.
The crash occurs when selecting an object which uses it's master style. I think it might be because I'm selecting using Layer explorer opposed to in the viewport. But not sure. I will update if I clarify the issue further.
Alex.S
Re: Crashes when updating Master Style
« Reply #1 on: February 14, 2019, 12:53:26 pm »
Ok, so creating a variable and changing it's type seems to be the issue. I've attached a test max file. Add a new numeric variable and change the type from integer to float in the rcMaster object, then click on the the rcSlave object. Crash everytime for me.
« Reply #2 on: February 14, 2019, 01:09:02 pm »
Thanks for report and detailed steps how to reproduce.
Confirmed. Added to the bug list.
Alex.S
« Reply #3 on: February 14, 2019, 01:18:37 pm »
I'm not sure that's the only way to get it to crash btw, in the end I have to unlink my master styles and relink after the changes.
