Author Topic: surface working in a 'reversed' mode from bottom, up  (Read 2513 times)
eligiusz
« on: May 28, 2020, 02:52:12 pm »
Normally You put the geometry above the surface but what if I want the surface to work as a ceiling and put the geometry below it ? Its probably something obvious but cant really find any setting for it.
Its not a big deal because I can just flip normals but that would then require having a separate object for RC and separate for rendering with normal normals.
Re: surface working in a 'reversed' mode from bottom, up
« Reply #1 on: May 28, 2020, 03:05:41 pm »
Yes, separate (non-renderable) object should work just fine.
Or maybe You could use surface normally and add additional transform to lower RC from the top to the bottom the amount You need.
eligiusz
« Reply #2 on: May 28, 2020, 03:08:50 pm »
what if I want some piping with 'holding geo' that adjusts to the ceiling ?
« Reply #3 on: May 28, 2020, 03:30:35 pm »
I guess your method works better then
