Author Topic: railclone tool octane render problem  (Read 20330 times)
IC8644
« on: January 09, 2014, 10:27:31 am »
I have problem with instancing by railclone tool. I have long chainlink, but raiclone object is instanced to the one mesh.
For better explain look the attachment please.
Maybe I´m doing something wrong.
Thanks a lot.
Jan
Re: railclone tool octane render problem
« Reply #1 on: January 09, 2014, 10:59:45 am »
Not all segments can instanced, only those what are identical to the original geometry (not deformed, sliced, etc.). So the instancing result depends a lot of how the RailClone object is designed.
If you send us your scene, we can check what is the problem exactly.
IC8644
« Reply #2 on: January 09, 2014, 11:48:19 am »
thank you for your quick reply.
Probably this is the problem, because now I noticed that the problem is not on straight area. So what is best way to create the most instanced long chainlink or curbs on the big  rough terrain?
Jan
« Reply #3 on: January 09, 2014, 12:40:41 pm »
I'm afraid there is no way to instance segments on a sloped surface, at least using "Vertical" mode, because all pieces must be deformed vertically.
You would use the "Adaptative" mode (see Segment->Deform), but obviously the result will be different.
In the attached image you can compare the instances generated by a chainlink fence, using both modes (instances are shown in blue).
IC8644
« Reply #4 on: January 09, 2014, 01:37:22 pm »
ok, I understand. logically :D
I tried it, it works. If the slope isn´t too big, it´s almost the same as vertical mode.
Thank for fast solution.
All the best
Jan
« Last Edit: January 09, 2014, 01:40:28 pm by IC8644 »
