Author Topic: Curb corner  (Read 3532 times)
IT1371
Curb corner
« on: April 24, 2017, 11:56:32 am »
In generally it looks fine and in overall i'm satisfied, but there is just one little thing about the corners that's not entirely right and I struggle to resolve.
At the moment the curb corners looks like this:
But its actually supposed to look like this:
This is the Concrete Curb from the library, but I made a custom style based on it.
Re: Curb corner
« Reply #1 on: April 24, 2017, 03:23:12 pm »
Thanks for the suggestion, I've added this to our wish list for improvements. Actually this should be relatively simple to achieve using a new Macro included with RailClone 3. Scale Final Segment X identifies the final segment in the array and allow you to rezise it to fill available space, it also has some setting to manually adjust the resultant size. Using this I can create the corner overlap you illustrate parametrically.
Video: http://d.pr/v/I3NF
Many Thanks,
IT1371
Re: Curb corner
« Reply #2 on: April 25, 2017, 07:37:00 am »
Hi Paul,
Thanks for your replay.
I tried some poking around with this Scale Final Segment but I can't understand how its supposed to be implanted.
In the video you attached it seems to work flawlessly, but when I try something similar the corners are not what I expected.
Can you please share a .max scene for me to breakdown and see where it went wrong for me?
Thank you!
p.s
Also there are 3 separate Scale Final Segment in the Macros list. They seem to be the same.
« Last Edit: April 25, 2017, 07:41:34 am by 3dcrgr »
Re: Curb corner
« Reply #3 on: April 25, 2017, 10:24:19 am »
Please find attached a sample file. There are a couple of parameters wired together but it should be pretty clear what's what from the files. You're right about the 3 Macros, there should be two - one for the X Axis, and one for the Y. It seems the name of the macro is too long to display so they look the same - I'll fix that and remove the extra one.
Thanks for the feedback!
IT1371
Re: Curb corner
« Reply #4 on: April 25, 2017, 01:23:56 pm »
Found what went wrong.
I just needed to disable the Slice checkbox in the Segment Properties:)
Thanks a lot for the help!
