Author Topic: Random on,off - switch to custom ?  (Read 3631 times)
Joker1979
« on: October 21, 2022, 11:06:38 am »
I have a question, is it possible to disable and enable the random modifier so that I can freely set the parameters manually. I attached the file in which I created a node with 3 numeric nodes  but I don't know if it can be connected somehow. I want to have a choice that I can send elements randomly or change to manual and choose the one that suits me. I need it because if I create two separate themes of random and custom building, I will occupy a lot of memory in the project and I would like to do it on one generator.
« Last Edit: October 21, 2022, 11:44:26 am by Joker1979 »
Re: Random on,off - switch to custom ?
« Reply #1 on: October 21, 2022, 11:42:17 am »
Can`t open file due Max`s version.
But, this can be easily done.
Joker1979
« Reply #2 on: October 21, 2022, 11:45:56 am »
I have overwritten the file to the 2018 version, you can download it again and see.  But I think what you sent me is what I was talking about thanks  Dragan !!!:)
« Last Edit: October 21, 2022, 11:57:23 am by Joker1979 »
« Reply #3 on: October 21, 2022, 11:48:38 am »
By right-clicking on the Operator (in your case the UVW XForm Operator) you can choose the Export Parameters and mark the On / Off. Once done you can wire these to the Numeric Operator, which should be set to the Boolean (0/1) Type. I hope that helps.
Joker1979
« Reply #4 on: October 21, 2022, 03:26:07 pm »
Problem solved. Thanks for advice :)
