RailClone => RailClone Pro (*) => Topic started by: mitviz on April 19, 2016, 09:17:08 am
hi, how do i get a better corner when using the curtain wall on a curved spline? for now it looks like this, edges look flared off
From your picture is looks as though the corner is defined by a number of vertices and each of these is generating a corner segment. In RailClone you can define what types of vertex generate a corner segment using the Vertex Type dropdown.
(http://docs.itoosoft.com/download/attachments/10092636/image2014-6-23%2014%3A16%3A8.png?version=1&modificationDate=1428479838000&api=v2)
If the style is currently creating a segment on Corner or Corner-Bezier vertices you could change the base spline so that it doesn't use either of these types. Alternatively you can use this dropdown to change the vertex types that generate a corner segment. For Example Change this to Corner to stop it adding segments on Bezier-Corner vertices.
Many Thanks,
