Author Topic: Building  (Read 2816 times)
lebonmarie
Building
« on: September 08, 2016, 05:31:59 pm »
I would liketo build my building with these parts but when I make my spline it doesn't work well. I  dn't  understand why, my windows are cut ...
How then I to make my roof at the same time?
Thank you very much
https://we.tl/YQIHPSllBo
Re: Building
« Reply #1 on: September 08, 2016, 05:59:49 pm »
Thanks for the file. The windows are cut because the generator is using Tile mode . This Mode slices the last segment on the side to fit between the corners.
Instead you could use Adaptive mode which subtly scales the geometry so that only whole segments are used.
I've also slightly adjusted the pivots and padding of the corner segments so that they fit together. Please take a look at the attached file and if you have any questions just let me know.
Cheers!
