Hi Dusan,
First, let me mention that, as you’ve pointed out,
Curtain Wall Curved 1 and
Curtain Wall Curved 2 Sun Shade are based on the same style setup - the other style simply shows the sun shade version of this preset.
To get a sharp corner, you should connect the
Selector operator (the one feeding the
Default input) to the
Corner input and enable the
Bevel Corner option once the
Bevel Mode is switched from
None to any other mode. To create a curved corner, simply adjust the
Corner >
Filler Radius value as needed.
The height can’t currently be set parametrically in the bundled style, but you can extract the involved segments (
Style Editor >
Segments >
Extract /
Extract All) and adjust them as needed.
Regarding the material, as mentioned in
this closely related post: “… while the Material IDs for the segments used in the
Sun Shade version correspond correctly to the assigned material, this isn’t the case for the
No Sun Shade option. I’ve adjusted them accordingly - the changes will be reviewed by our team, and the updated styles will be published soon.”
I hope this helps.
