Author Topic: Curved wall  (Read 2672 times)
Ignacio
Curved wall
« on: June 01, 2023, 02:39:44 pm »
Hello all!
I am trying to make a wall based on different rock instances.
I am using an array 2s, the base object is a rectangle.
Any idea of how to proceed in the curved area? If i bend the rectangle the railclone gets crazy...
Re: Curved wall
« Reply #1 on: June 01, 2023, 02:43:34 pm »
Upon the provided screenshot, it looks like, you’re using the Extend X/Y Size to Area mode which isn't suited for this kind of purpose - you should use the X Spline Input instead.
Ignacio
Re: Curved wall
« Reply #2 on: June 01, 2023, 03:13:02 pm »
Hello Michal
Thank you for your reply.
If I use just a spline withouth any height, how could I specity the wall height? That is the reason I am using a rectangle.
Maybe a basic thing, but I am stucked :(
Best
Re: Curved wall
« Reply #3 on: June 01, 2023, 03:25:18 pm »
You can easily define it by using a Y Spline or just by entering the corresponding value to the Y Size parameter of the Array 2S.
Ignacio
Re: Curved wall
« Reply #4 on: June 01, 2023, 05:58:39 pm »
Thank you very much for your help, I think I got it
Best
