Author Topic: Curved Wood cladding or Free form facade  (Read 20671 times)
Mouton
« on: January 04, 2019, 07:22:10 am »
Hi Itoo
How do i go about achieving this type wood cladding on a curved wall with deff wood sizes because i have no clue how to do this
Regards
Mouton
Re: Curved Wood cladding or Free form facade
« Reply #1 on: January 04, 2019, 10:06:44 am »
Thanks for this question.
I would suggest using nested style workflow. First do a one column of cladding (2) from simple piece of geometry (1).
Then use  this created segment(2) in Master RailClone style (3).
As it will be higher than needed use clipping spline(4) to cut the roof to Your desired shape.
Attached file for closer investigation.
Hope this helps.
Mouton
« Reply #2 on: January 04, 2019, 01:50:34 pm »
thnaks rokas
help allot
while i have you on the line here having trouble with this kinda cladding facade
cant get is smoothed and spaced correct
« Reply #3 on: January 04, 2019, 03:05:32 pm »
You can easily fix current setup:
I hope this solves the issue.
Mouton
« Reply #4 on: January 04, 2019, 04:53:22 pm »
thanks Rokas
so simple :)
maknev
« Reply #5 on: January 07, 2019, 11:01:19 pm »
wow I was trying to make the same exact brick layout for some time now!
Can you please post more settings, is the segment the same (Box001), then why is it sequenced?
M55
« Reply #6 on: January 10, 2019, 08:03:13 am »
i wonder what would be a good approach to texture the first cladding with some variation in this thread
i tried but without easy success because the parts are getting scaled in the first Railclone and that is getting scaled in the second Railclone
so i guess you have build the parts for the first railclone  and so on ???
« Last Edit: January 10, 2019, 08:08:26 am by M55 »
M55
« Reply #7 on: January 10, 2019, 08:40:44 am »
OK i got it
i inserted a material node and activated the Mapping in both railclones ... that did the trick
OMG   :)
« Last Edit: January 10, 2019, 08:42:35 am by M55 »
« Reply #8 on: January 10, 2019, 09:53:49 am »
Great if that works for You.
I have modified style(all parameters are now in First RC object) to have more flexibility as well as different UV mapping approach:
M55
« Reply #9 on: January 10, 2019, 10:46:33 am »
thanks rokas
nice if we can have it all in the first railclone  :)
would be great if we could also get a additional slight variation in z in the first railclone
anyway i learn a lot
« Last Edit: January 10, 2019, 10:54:33 am by M55 »
« Reply #10 on: January 10, 2019, 10:55:11 am »
so yes all of the mentioned parameters are in first RailClone.
M55
« Reply #11 on: January 10, 2019, 11:11:27 am »
my mistake  8)
i remembered the first Railclone to have additionally difference in hight (different thickness of each board) but that was not the case ... makes no sense anyway
so everything is perfect
thanks
PH4128
« Reply #12 on: February 05, 2025, 11:18:44 am »
Hi all,
I was used this Railclone from year et now with the upgrade to the 9 version. it no longer works.
I lose all random effect...
« Reply #13 on: February 05, 2025, 01:31:10 pm »
In RC6, there is an issue with nesting RC objects - I can confirm that this has already been fixed in the upcoming RC7. If you prefer using RC6, you can merge these graphs instead. I’ve attached a revised version of the scene for your reference.
I hope this helps.
PH4128
« Reply #14 on: February 06, 2025, 09:16:26 am »
So nice! Thank you!
