Author Topic: stepped deform mode in groups  (Read 11140 times)
Troy_1234
« on: February 04, 2025, 12:31:21 pm »
I have a featherboard fence set up where the boards are individual, rather than one object per panel (as panel lengths vary in smaller areas etc.) When applied to a surface the structure is set to stepped so it steps down each panel. How can I make the boards follow suit rather than stepping each one and therefore extending out of the top and bottom?
Thanks!!
Re: stepped deform mode in groups
« Reply #1 on: February 04, 2025, 01:08:28 pm »
Thanks for the question. Please take a look at the attached file. I've nested the Pickets Generator inside the Posts Rails generator as a default segment. I've also combined it with the existing Railings segment using a Compose operator. The X Size of both of those is set using an expression that finds the available space on a spline section, as follows:
return Posts_Rails.XSectionAdjustedLength;
Cheers,
Troy_1234
« Reply #2 on: February 06, 2025, 01:37:06 pm »
Hi Paul,
That's fantastic thanks. Great service as always! I've learned a lot from that as well.
« Reply #3 on: February 06, 2025, 01:46:47 pm »
You're very welcome - happy I could help out.
Cheers,
