Author Topic: Segment Object doesn't follow Spline with Transform Operator  (Read 4781 times)
FL3195
I'm trying to create an architectural animation with cars moving along the winding street, using Railclone to distribute dozens cars model along Spline. I add Transform operator to animate the cars moving forward. But when i tried to move the car along X axis (forward) with Transform Operator, the cars model doesn't move forward along the spline. Instead it just move straight forward along its own x axis.
Is there any setting to force the car move forward along the spline? Screenshot attached below.
I'm on 3ds max 2016 & Railclone Pro 3.1.0.
Thank you.
« Last Edit: May 24, 2018, 09:44:09 am by FL3195 »
Re: Segment Object doesn't follow Spline with Transform Operator
« Reply #1 on: May 24, 2018, 09:56:36 am »
Thanks for question.
One way to animate objects moving along a spline would be to use Spline properties. Disable Full Length and animate parameters to Your liking:
FL3195
« Reply #2 on: June 02, 2018, 02:32:25 pm »
sorry for late reply. Looks like it was just a bug in cloud point mode view. Because when i changed to box or mesh display, the segment move back to the spline and can be animated along the spline by exporting the parameter and use numeric operator.
