Author Topic: Mapping  (Read 3193 times)
Mapping
« on: February 03, 2020, 01:54:34 pm »
Hi.
3dsMax is not my primary software (I use RC & FP as both plugins have the logic that  I`m very comfortable).
I have a problem with a proper mapping solution for the window frame.
Does anyone have an idea of how to set up everything to:
- avoid scaling,
- use real-world map size
- keep the corner segment with split map orientation?
I use Default scale mode to reduce the number of segments.
I also use the trick to oversize Y Size of the segments instead to calculate, so RC will slice them automatically.
Both options will scale the bottom/top/sides segment and texture too.
-Corona
Any idea?
« Last Edit: February 03, 2020, 04:14:27 pm by Dragan »
Re: Mapping
« Reply #1 on: February 04, 2020, 10:40:25 am »
Hi Dragan
I am glad I can help You this time ;)
Hope this helps.
Re: Mapping
« Reply #2 on: February 04, 2020, 10:52:13 am »
 ;D I`m glad you helped.  ;D
Re: Mapping
« Reply #3 on: February 04, 2020, 11:09:59 am »
I  just saw style.
%$^$$^^&%%&*^*#$@$#@#   :D ;D :o
This should be sent to the Development team to see.
 We need some elegant node to solve this problem.
Thank you for your hard work. If I had known that it was so`easy` I would never have posted the question.
Re: Mapping
« Reply #4 on: February 04, 2020, 11:28:12 am »
Just few uvw xforms. I can hidethem inside macros if You want.
Re: Mapping
« Reply #5 on: February 04, 2020, 11:34:49 am »
No, no... I understand complete style. I will do macro on my own. I just thought this could be solved in a much easier way.
Thank you for help I will look more into mapping in the future.
Best Regards.
