Author Topic: default railing woes  (Read 3306 times)
TL1895
« on: September 14, 2015, 06:08:51 pm »
Please tell me how I can correct this obvious problem?
Thanks a lot!
TL1895
Re: default railing woes
« Reply #1 on: September 15, 2015, 03:10:04 pm »
If you turn on Bend and set the Deform mode to Vertical for hrmetal_start5 and hrmetal_end6 you should find the step is removed.
Many thanks,
TL1895
« Reply #2 on: September 16, 2015, 11:53:19 am »
Deadline past, but I will give it a try on the next submission. thank you
