Author Topic: Railclone PRO object dissapears when collapsing to editable poly/mesh  (Read 5541 times)
Adi S
Hey guys , i need an urgent help with this. As mentioned in subject, my railclone object dissapears when collapsing to ediable poly or mesh. I tried also adding edit poly ,edit mesh and mesh select modifier and same thing happens.
Any help with this ?
https://www.dropbox.com/s/1cwgdklzl5ktzb4/RC%20problem.gif?dl=0
Re: Railclone PRO object dissapears when collapsing to editable poly/mesh
« Reply #1 on: October 26, 2019, 09:01:45 pm »
Check the display mode for RC. Try to set it to Mesh before applying a modifier or collapsing to editable poly or mesh.
Adi S
« Reply #2 on: October 26, 2019, 10:17:33 pm »
Thank you, it worked. I actually knew this already but I used Quick Mesh display mode which looks similar (or the same in my case) so I overlooked that possibility.
