Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Deform Flat Top Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Deform Flat Top Problem (Read 4169 times)
alessandro.d84
Newbie
on:
March 20, 2022, 11:48:46 am »
Hi, i'm trying to follow the " How to model stairs with RailClone in 3ds Max " But when i try to use the Flat top option nothing happen no matter what value i put inside.
I really do not understand why.
Thanks, Alessandro
Logged
Hero Member
Re: Deform Flat Top Problem
Reply #1 on:
March 20, 2022, 12:36:00 pm »
Try a smaller value, there are a few differences between RC4 and RC5. It should be measured upwards from the X Spline.
Logged
alessandro.d84
Newbie
Reply #2 on:
March 20, 2022, 12:46:43 pm »
Hi, I ve tried also small value but nothing change.
The workaround that I found is to align the bottom of the segment instead of the top than offset the array.
But like this I m confused on how the flat top works.
Logged
eqko
Full Member
Reply #3 on:
November 23, 2022, 11:19:31 am »
A coworker of mine trying to get up to speed on RailClone also ran into this one today..
Is there a known or preferred change in setup or workaround ?
Or is it a bug that's still in RC 5.2.7 ?
Logged
Hero Member
Reply #4 on:
November 23, 2022, 11:37:22 am »
Check this topic. Paul has explained. It is not a direct answer to your question but maybe it can help to understand.
https://forum.itoosoft.com/railclone-pro/curevd-top-but-a-flat-base/
Logged
eqko
Full Member
Reply #5 on:
November 23, 2022, 12:03:33 pm »
Ah so the cause in the tutorial is basicaly the thread segment using top alignment (making it drop below the path).
When I set it to bottom it indeed works.
Perhaps update the Tutorial files to reflect this ?
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
