Author Topic: Delete key failure issue  (Read 10258 times)
QN1156
« on: June 04, 2024, 05:41:18 am »
If you click in the order of 1, 2, 3 and then select other objects, the Delete key will become ineffective. You must click 1 again to exit the selection in order to restore the Delete key. I was confused by this problem for a long time and found this solution. I hope I can correct this error.
Re: Delete key failure issue
« Reply #1 on: June 04, 2024, 08:51:31 am »
With your help, we have been able to reproduce this behavior here as well. It will need to be investigated more in depth by our main developers and hopefully, a solution will be found soon. We greatly appreciate your feedback, it is very important to us.
BK8837
« Reply #2 on: July 01, 2024, 09:17:44 pm »
Thanks for finding this. The delete key becomes unavailable and the only way to get it back is to save and close the file and restart max. This takes quite a long time. I kind of wondered it it was FP or RC that was causing this.
