Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
railclone small plane tiles with multi texture
« previous
next »
Print
Pages: [
1
Author
Topic: railclone small plane tiles with multi texture (Read 2706 times)
Uwe Kreuzahler
Newbie
3D Visualization Director
on:
September 07, 2020, 09:27:40 pm »
Hello
I'm using the railclone small plane tiles (from the library) for a roof, but cant get multi texture working
The idea is that i use 5 - 8 different bitmaps and spread them over the whole area.
Can someone help me to achieve this?
Logged
Photorealistic Architectural Visualizations
www.3D.cr
Hero Member
Re: railclone small plane tiles with multi texture
Reply #1 on:
September 08, 2020, 08:45:37 am »
Hi.
Let me explain the difference between
multitexture
and
RailClone Color
maps.
Multitexture works on material IDs. You need to randomize material IDs (RailClone has a node for that). RailClone color works on segments. No need to randomize IDs.
P.S. If You are using multitexture and Your segment has some other materials apart the one with multitexture, all possible variants need to have same material instance in multi-sub object material:
Both maps have their strengths and weaknesses. It is up to You which to use in Your situation.
Hope this helps
Logged
Uwe Kreuzahler
Newbie
Reply #2 on:
September 08, 2020, 05:52:52 pm »
Hi Rokas
thanks for the answer, I used the MaterialID node and that did the trick :-)
regards
Uwe
Logged
www.3D.cr
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
