Author Topic: Null corner deforms evenly stepped projection (1S)  (Read 2940 times)
nubo
« on: March 25, 2021, 03:22:41 pm »
I've noticed in 1S generator that if you put dummy object or no object at all in corner slot while using surface and having only evenly objects generated (no default or default is also null) then stepped mode doesn't work properly for those evenlies. It rotates these objects along X axis. If you put any real geometry in corner or default slot it works fine.
Is it expected behaviour or is it a bug?
Best Regards,
Przemek
RC 4.2.1
scene attached
Re: Null corner deforms evenly stepped projection (1S)
« Reply #1 on: March 25, 2021, 03:28:13 pm »
A bug. Thanks for reporting.
