Author Topic: Making a door and frame - can't figure out how to get a specific spline length  (Read 3008 times)
CB4719
I have attached a simplified version of a railclone door and frame I am creating using a single spline with 4 segments. The frame is constructed using a 2d array and the door itself uses a linear array as I rotate the door open around the axis of the spline it is generated on. I have not been able to figure out how to generate (get) procedurally the width of door (along the x-axis indicated in the image file). I am able to retrieve the height of the door (indicated in image along the y-axis) since this is simply the length of the spline it is generated on.
Brian
Unfortunately using Clipping Splines sometimes reduce RailClone style flexibility.
In such case it would be better to use X Spline And Y Spline Separately. Or even not use Y spline but use Numeric node.
This way You will get more control:
CB4719
Thank you Rokas for your quick response!
I also have implemented a window casing and door casing railclone object which utilize a linear array and was hoping to only have to one spline to be able to attach all railclone object creations to instead of having a separate spline for each the door and the door casing.
When I have time maybe I will post a simplified version of my casing railclone object to get suggestions on whether what I am doing there could be simplified and share the same X spline/Yspline separately or numeric node as you have suggested for the door object below.
Thanks again.
Brian
