Author Topic: Independence of generators inside the same Railclone object  (Read 2556 times)
Chulit
Hi, just getting a little more serious with Railclone, and have a question regarding the relationship between independent generators inside the same RC object.
I have several 1S generators in the same object, every one with it's private segments and splines. It's a simple setup for several lines of trees of different species.
All are working with evenly distances and the trees are placed where I want them.
But if I turn off any separate generator, the distributions and rotations of the segments on the other generators change.
Is there any setting to avoid this behaviour?
THanks in advance,
Matias
Re: Independence of generators inside the same Railclone object
« Reply #1 on: June 07, 2022, 07:40:11 am »
You probably using Segments>Transform>Random Rotation/translation/Scale on Orange Segment Node. That values will randomize each time when something is changed inside the Style.
You should add a Transform node after the Segment node, export parameters for Rotation/Translation/Scale, and add a Random numeric node. With a Random node, you have several options to control how randomization should be applied.
Chulit
« Reply #2 on: June 07, 2022, 03:48:43 pm »
Thank you Dragan for the detailed explanation!
Will try it today for sure that wiring.
Best regards and thanks again
