Author Topic: How to have variable width 2S Array  (Read 3081 times)
Alex.S
« on: April 11, 2019, 11:15:13 am »
I'm wondering if it's possible to adjust the width of a 2S Array based on the XSpline?
I'm trying to achieve stacks of tyres with different levels of depth.
At present I'm just assuming it needs to be done in a post RC step. I setup the width as a static parameter and just remove elements I don't want. But it'd be cool if I could adjust that in real time. I'm placing the stacks using X-Evenly btw as this gives me the best control of position (I get overlapping issues if I use Default, Top, Bottom etc)
I did try using a clipping area but found it a bit unreliable and difficult to generate.
An additional thing I'd like to achieve is a conveyor belt that goes around them somewhat similar to the black line here, but I think I'm probably just best manually drawing a spline and create a profile that uses that....
Just throwing it out there in case anyone thinks of something I haven't considered though.
Re: How to have variable width 2S Array
« Reply #1 on: April 12, 2019, 10:47:39 pm »
What seems to be the problem? Works well in this case:
Attached file.
I don't think You should consider RC for this task.
Alex.S
« Reply #2 on: April 14, 2019, 06:49:11 pm »
Thanks, in the end i added per row start and end offset values for the profile. I found this simpler than using a clipping spline.
