Author Topic: Disable instance engine for specific item in library  (Read 2710 times)
IT1371
« on: May 24, 2017, 03:04:26 pm »
I made this style and added it to my user library in RC.
Anyway this style only works correctly when the  instance engine is off.
So is there some way that instance engine will automatically turn off when I load this specific style only?
I always forget to turn it off, and since it looks fine in the viewport I just waste render time.
Re: Disable instance engine for specific item in library
« Reply #1 on: May 24, 2017, 03:23:37 pm »
Thanks for the question. We've been having the same conversation here lately where libraries only work correctly if instancing is turned off for particular renderers. As a result, future versions of RailClone will include a functions that can be called to disable instancing if the current renderer doesn't support a feature. It will use the following syntax that should be added to the library's index.xml.
<maxscript script='@RC_disableInstancing "$(RENDERER)" "corona";' execute_on="item_select"/>
Where corona is the renderer for which you would like instancing disabled. Other options include mentalray, and vray.
If you would like to disable instancing for multiple renderers, just add them separated by a space, e.g.
<maxscript script='@RC_disableInstancing "$(RENDERER)" "corona mentalray";' execute_on="item_select"/>
I'm afraid this won't work quite yet, but the next builds of RailClone 3 will include the function to which this line refers, so you can start using it then.
Many Thanks,
IT1371
« Reply #2 on: May 25, 2017, 10:15:41 am »
Hi Paul,
Thanks for your answer.
Will be waiting for RC3 :)
