Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Sequence of Generators & Marker
« previous
next »
Print
Pages: [
1
Author
Topic: Sequence of Generators & Marker (Read 6067 times)
arch3d
Sr. Member
on:
December 13, 2020, 05:35:33 am »
sorry for stalking you again
here is some problem:
i got two generators as sequence of default segments, i would like to separate them by marker and assign it to part of spline ( e.g. ID=2 )
is it even possible?
problem cause limits, i know RC consider whole spline
if i turn them off works fine even if structure isn't perfect
Last Edit: December 13, 2020, 05:52:50 am by arch3d
Logged
Hero Member
Re: Sequence of Generators & Marker
Reply #1 on:
December 13, 2020, 08:56:01 am »
You can handle the rest
Logged
arch3d
Sr. Member
Reply #2 on:
December 13, 2020, 11:15:27 am »
Thank you very much,
But how to limit sequence to deired matID?
Logged
Hero Member
Reply #3 on:
December 13, 2020, 11:42:05 am »
I`m not sure I understand.
Do you need an additional limit for the spline IDs?
Logged
arch3d
Sr. Member
Reply #4 on:
December 13, 2020, 12:44:18 pm »
much more closer, i hope screen will explain what i want
Last Edit: December 13, 2020, 12:50:28 pm by arch3d
Logged
Hero Member
Reply #5 on:
December 13, 2020, 01:36:52 pm »
Just enable mat id limit in main generator.
Logged
Hero Member
Reply #6 on:
December 13, 2020, 02:07:43 pm »
This will change the start position of the marker.
Strange, I tried with selector Selector, Compose+null for termination, Conditional, nothing works as should.
Logged
arch3d
Sr. Member
Reply #7 on:
December 13, 2020, 02:12:05 pm »
i know it could be RC limitation
Logged
Hero Member
Reply #8 on:
December 13, 2020, 02:16:51 pm »
Ah I see. Yes
it is
Logged
Hero Member
Reply #9 on:
December 13, 2020, 02:44:44 pm »
You could do a workaround with conditionals.
Logged
arch3d
Sr. Member
Reply #10 on:
December 13, 2020, 02:58:09 pm »
nice!
Logged
arch3d
Sr. Member
Reply #11 on:
December 13, 2020, 03:06:18 pm »
so if i would extract position of marker on spline i could use it as conditional's spline position am I right?
Logged
Hero Member
Reply #12 on:
December 13, 2020, 03:53:43 pm »
Yes.
I don`t know why the Conditional Length of the Full spline is not working. Possible bug again.
When the marker is connected it will automatically make a Section on the spline so you probably can calculate the marker position in Percentage.
I guess something like XSectionLength/XSplineLength*100. (connect this to Conditional node). Although I`m not sure how this will affect Sequence change. It is possible that some of the Sequence segments `crossover` the Marker Cone Segment. Then you just make the threshold by multiply with a value around 100. +/-80/90...
I can test it when I get my hands back on the computer.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
