Author Topic: distance between wood strips  (Read 6835 times)
enzo_87
    • www.lorenzospinola.com
« on: June 25, 2020, 06:42:58 pm »
Good evening,
I'm trying to create for the first time an herringbone floor.
following the video on the website, I create my wood strip, 27x8, my clipping area, connected everything and it works.
I add the herringbone macro and works, but when I try to add some space between the wood strips the floor disappear.
to do it I'm doing:
-selecting the segment
-fix size, untic the scale paramenter
-putting a bigger dimension, like 27.2 x 8.2
without the macro node it works, but with it it's not working.
Am I doing something wrong? is there another way to do so?
thanks in advance,
Lorenzo
Re: distance between wood strips
« Reply #1 on: June 26, 2020, 07:35:08 am »
Hi Lorenzo
I have attached modified macro to include a gap setting. It needs some manipulations. It is not enough to edit segments size.
I have also included a advanced herringbone macro that was used in this tutorial. Feel free to use it as well.
Ricousto
« Reply #2 on: April 17, 2024, 06:07:50 pm »
Would it be possible to access to modified macro ? I can't open the attached.
Thanks a lot
Hi Lorenzo
« Reply #3 on: April 18, 2024, 09:13:01 am »
Of course, please find attached the used macros (SegmentToHerringbone.rcm & AdvHerringbone.rcm) and the sample scene (HerringboneSampleScene_iToo.max) saved in the 3ds Max 2021 format. I hope that helps.
Ricousto
« Reply #4 on: April 18, 2024, 09:36:45 am »
Thank you !
IMHO These macros should be in the default library
