RailClone => RailClone Pro (*) => Topic started by: enzo_87 on June 25, 2020, 06:42:58 pm
Title: distance between wood strips
Post by: enzo_87 on June 25, 2020, 06:42:58 pm
Good evening,
I'm trying to create for the first time an herringbone floor.
following the video on the website, I create my wood strip, 27x8, my clipping area, connected everything and it works.
I add the herringbone macro and works, but when I try to add some space between the wood strips the floor disappear.
to do it I'm doing:
-selecting the segment
-fix size, untic the scale paramenter
-putting a bigger dimension, like 27.2 x 8.2
without the macro node it works, but with it it's not working.
Am I doing something wrong? is there another way to do so?
thanks in advance,
Lorenzo
Title: Re: distance between wood strips
Post by: Rokas on June 26, 2020, 07:35:08 am
Hi Lorenzo
I have attached modified macro to include a gap setting. It needs some manipulations. It is not enough to edit segments size.
I have also included a advanced herringbone macro that was used in this tutorial (https://www.itoosoft.com/tutorials/parquet-floors-for-unreal-and-3ds-max). Feel free to use it as well.
(https://i.imgur.com/6bZ8pOX.png)
Post by: Ricousto on April 17, 2024, 06:07:50 pm
Would it be possible to access to modified macro ? I can't open the attached.
Thanks a lot
Hi Lorenzo
Post by: Michal KarmazĂ­n on April 18, 2024, 09:13:01 am
Of course, please find attached the used macros (SegmentToHerringbone.rcm & AdvHerringbone.rcm) and the sample scene (HerringboneSampleScene_iToo.max) saved in the 3ds Max 2021 format. I hope that helps.
Post by: Ricousto on April 18, 2024, 09:36:45 am
Thank you !
IMHO These macros should be in the default library
