Author Topic: Follow Spline but deform to ground  (Read 9455 times)
SR1351
« on: June 19, 2024, 07:08:09 pm »
I have a decorative sculped wall that I need to deform in a way I cannot figure out. I need it to follow a spline but deform to the ground.  So another words I would like for the top of the wall to follow the spline but the bottom of the wall to glue and deform to the grading of the ground. How would I go about this?
Re: Follow Spline but deform to ground
« Reply #1 on: June 20, 2024, 09:33:40 am »
You can use the XSplineCoords.z attribute to drive the Z Fixed Size of the Segment. Please find attached a sample scene (240620_XSplineCoordsZSampleScene.max).
SR1351
« Reply #2 on: June 20, 2024, 04:57:29 pm »
Thank you so much for the help, I have two issues I still cannot figure out.
1) I need to be able to slope the spline it follows for the top of the wall also. When I slope the spline for the top of the wall it stays flat.
2) I need the object to morph so it's smooth and not jagged like in the image I attached. Hope this makes sense.
« Reply #3 on: June 21, 2024, 11:05:21 am »
In this case, it would be advisable to split it into two Generators. Please find attached a sample scene illustrating the possible style setup. Depending on the segment used, you can adjust the Deform > Flat Top / Flat Bottom parameters accordingly. I hope this helps.
