Author Topic: Door parametric size  (Read 6306 times)
UB1191
« on: June 10, 2018, 10:39:01 pm »
Hey guys!!
i have a lot of projects where i have to adjust door/fix panel size..in this case i would like to be able to adjust handle size as well..so i can use my model as window and door!
I started with:
LT corner: 1  RT corner: 15
LD corner:7  RD corner: 21
TOP: 8  BOTTOM: 14
now... how can I manage parts 2, 3, 4, 5, 6 on the LEFT side; 16, 17, 18, 19, 20 on the right side; 9, 10, 11, 12, 13 as default; and to be able to change door and handle hight.
1. example: I have opening height of 250cm..door hight will be 200cm and rest fix window, and i will set handle hight at 100cm
2. example: I have window opening hight of 150cm..window will take 100cm, rest is fix and handle on 50cm.
Thanks for your help!!
Re: Door parametric size
« Reply #1 on: June 11, 2018, 11:23:57 am »
great question.
You should consider my colored segment groups as one segment and plug them to Bottom Corner, Bottom and another Bottom Corner. You can use compose operator to combine them (with exported parameter for 6 13 and 20 for adjustable height )
P.S. Slice segments so their size in X and Z size are round values like 10.0 or 15.0 cm it will be a lot easier later.
If You have any problems, please share Your progress and I will try to help as much as I can.
« Last Edit: June 12, 2018, 08:04:08 am by Rokas »
UB1191
« Reply #2 on: June 11, 2018, 10:57:02 pm »
Hi mate,
i followed your way...but when I place bottom part i end up with (in my opinion) composed objects gap...then i tried to adjust left/right padding...but it doesn't help!
Can you help me with this part?
Thanks and best regards!!
« Reply #3 on: June 12, 2018, 08:42:14 am »
I have played with some padding/transform values.
It is easy to work with segments when they are 15.00 cm in size:
UB1191
« Reply #4 on: June 12, 2018, 04:29:20 pm »
Hey Rokas...i think i am almost done with my windows!! :D
How can I correctly set start, end and default connections??
Thanks!!
