Author Topic: Railclone not filling out spline...  (Read 2638 times)
LC3D
« on: July 04, 2022, 04:13:19 am »
Hey there,
I'm new to Railclone and trying to work out why sometimes RC wont fill out a spline?
See attached image.
The pink spline is one spline - well multiple splines that I've attached to create one spline as you can't have multiple splines/clipping areas for 1 railclone object.
I've tried resetting the x-form and reversing the spline, if I detach the part of the wall that is causing the issue and create a new RC spline then it works fine, but ideally I'd like to have it all attached to one spline as I have a lot of railclone objects in this scene.
I should also mention, this is just the cladding macro, with my own peice of cladding as the geometry/segment.
any advice would be greatly appreciated.
Thanks.
« Last Edit: July 04, 2022, 04:17:07 am by LC3D »
Re: Railclone not filling out spline...
« Reply #1 on: July 04, 2022, 09:27:07 am »
Thanks for getting in touch. Would you mind uploading that scene so I can take a closer look.
Thanks!
