Author Topic: Update seems to have cause errors in my preset Lib  (Read 4545 times)
Adam86
« on: May 21, 2019, 05:04:10 pm »
Hi, since updating I have found creating new presets of my own custom presets not working as expected. I created a preset, then I saved it in my preset Lib as always. Now when i try to load that preset into a new scene via Railclone Lib browser, it doesn't appear to do anything and does not load anything. the only way for it to work is for me to merge the Railclone from the preset file into a new file. Am I doing something wrong? I've got dozens of Presets that have never been a problem before and I am following the exact same procedure.
Interestingly, I also updated a preset in the preset scene and now when i try to 'load' it via lib browser in a new scene i get a Railclone Pro error message stating that the entire preset file 'is not a valid RailClone object'!!! again only work around is to merge the railclone through Max...
thanks
A
Re: Update seems to have cause errors in my preset Lib
« Reply #1 on: May 21, 2019, 08:43:33 pm »
hi
Please compress whole library folder and send to us. we will check it.
Please use this form to contact us if You can't attach files publicly.
