Author Topic: Repeat geometry between start and end on evenly or corner  (Read 5006 times)
HP3623
« on: March 12, 2018, 01:48:42 pm »
I try to generate a style for shelves (using A2S generator). Problem is that they should be parametrically for exact different sizes. To create one shelve wall I'm using 2 geometries, on for the start/end and one for in between. When creating the exterior walls this works great with the corner elements and the left/right side elements. But this doesn't work for evenly or inner elements.
Is there anyway I can say use geometry nr. 01 for start and end and repeat geomerty nr.02 in between start and end?
Re: Repeat geometry between start and end on evenly or corner
« Reply #1 on: March 14, 2018, 01:30:27 pm »
thanks for the question. I am a little unclear on what you are trying to achieve. Would it be possible to add some screenshots, or even better add a scene file to help explain the problem?
You can certainly use different geometry in the left and right sides of the array, but I think your question might be asking for something more specific.
Many thanks in advance,
