Author Topic: Small Plane Tiles with Decorative rows preset tweak  (Read 2839 times)
iToo_Butler
    • DJS CGI
« on: June 12, 2019, 01:11:30 pm »
Hi all,
I'm using the Small Plane Tiles with Decorative rows preset for some vertical hanging tiles on a house. I have set the Y counts to match the design intent, but I need to shift all the tiles up in the Z axis to put the decorative tiles where I want them to match a DWG I have.
I thought the ZOffest in the Top Level macro would shift them up in the world Z, but they move inwards along their Y axi instead. Is there a way to shift their position in the world Z by exposing this as a parameter?
Thanks in advance.
Andy.
Cheers,
iToo_Butler.
Re: Small Plane Tiles with Decorative rows preset tweak
« Reply #1 on: June 12, 2019, 03:10:18 pm »
Hi. For this You will have to step inside the macro and do steps:
Unplug spline node.
Disable extended X/Y size to area
Enter manually Your dimensions in X and Y parameters
Adjust RC object position to Your liking
Rewire clipping area (optional)
Hope this helps
iToo_Butler
    • DJS CGI
« Reply #2 on: June 12, 2019, 03:44:42 pm »
You are a gent.
That works, with some small problems, but nothing that isn't easy to rectify.
Thank you.
Cheers,
iToo_Butler.
