Author Topic: edit setting for multiple segments in editor?  (Read 4901 times)
TL1895
« on: May 01, 2015, 04:54:47 pm »
Suppose you have a style set up, and you have several segments that will always have the same UVW box mapping applied.
Is there a way to edit those settings at once, or only by going into each segment one at a time?
Hopefully this image will make it clear...
In this image, there are only 5 segments, but what if I had to do this for 50, 100?
Many thanks!
TL1895
Re: edit setting for multiple segments in editor?
« Reply #1 on: May 01, 2015, 06:47:35 pm »
Hi, You Edit One and then clone multiple times:
Watch here
Whole video is packed with useful info, but the part You are interested in is described @ 8:50
TL1895
« Reply #2 on: May 01, 2015, 07:00:52 pm »
So if I have 50 to change,  I would delete 49 of them, make changes to the remaining one, and finally re-clone that one 49 times?
This is good for totally identical segments, but there are 50 unique segments, but they all need the same UVW coords.
So, I would still have to individually edit them.
Thanks again!
